[mapguide-internals] Re: 2.1.0 Final Windows Installer
Trevor Wekel trevor_wekel at otxsystems.com
Fri Nov 20 11:39:32 EST 2009
Ok.  I've made a couple of minor modifications to the text based on the OSGeo News posted 2.0.0 release.  The text for the mail lists is below.  The HTML formatted text for the OSGeo news posting is attached.
Hello,
We are pleased to announce that the MapGuide Open Source project team has released MapGuide Open Source 2.1.0.
Release notes: http://trac.osgeo.org/mapguide/wiki/Release/2.1/Notes
Downloads: http://mapguide.osgeo.org/download/releases/2.1.0
Documentation: Please continue to use the 2.0 documentation for now.
Along with the many bug fixes, this release has
* many improvements in performance, scalability and stability;
* an improved error reporting system;
* raster re-projection;
* and CS-Map as the coordinate system library.
Thanks to the ever growing team of developers who are contributing to make the MapGuide Open Source project a more self-sustaining project.  A special thanks to Jackie and Jason who worked tirelessly on the Windows installer and builds.
The MapGuide Team
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: November 19, 2009 7:35 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Re: 2.1.0 Final Windows Installer
I can keep my local 2.1 build environment around for whenever that
patch happens. I think it may be more important for the current system
to track trunk as semi-continuous build system? Probably better not to
waste efforts on 2.1...
Oh. There's a doc somewhere on the osgeo website or wiki showing how
to submit major release news to OSGeo for announcement. That (and a
post to mapguide-announce & -users) are important steps.
On 2009-11-19, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> Yep.  Check out from Linux and run an svn export to create a clean tree.
> The line endings change and I think the Linux checkout also makes a
> difference on the execute permissions for the various shell scripts.
> This might take me a couple of days.  I don't have a Linux development
> environment set up at the moment.  I should probably install VMware on my
> extra Dell box and go from there.  Not a big deal.  Just more busy work.
> I wonder if we should leave the existing Windows build VM at 2.1 instead of
> moving it to 2.2?  I suspect the community will want an MGOS 2.1 patch at
> some point.
> Thanks,
> Trevor
> Sent: November 19, 2009 6:44 PM
> Cool.
> It would be great if we could post a tarball of the source checked out
> on linux (I think line-endings etc change?).
> Not sure if would be better to just zip up including .svn directories
> (good starting point) or to export from local repo for a cleaner tree.
> Maybe both :)
>> Hi Jason, I am updating the Drupal website.  Should we also post the
>> source
>> code as we did for previous releases?  I can perform the SVN checkout and
>> zip locally assuming we are using version 4283.
>> And thank you for your many tireless hours on this release!
>> Regards,
>> Trevor
>> View this message in context:
>> http://n2.nabble.com/2-1-0-Final-Windows-Installer-tp4023684p4034013.html
>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
<html>
<body>
<p>We are pleased to announce that the MapGuide Open Source project team has released
<ul>
<li><a href="http://trac.osgeo.org/mapguide/wiki/Release/2.1/Notes">Release Notes</a></li>
<li><a href="http://mapguide.osgeo.org/documentation.html">Documentation</a></li>
<li><a href="http://mapguide.osgeo.org/download/releases/2.1.0">Downloads</a></li>
</ul>
<p>Along with the many bug fixes, this release has
<ul>
<li>many improvements in performance, scalability and stability;</li>
<li>an improved error reporting system;</li>
<li>raster re-projection;</li>
<li>and CS-Map as the coordinate system library.</li>
</ul>
<p>Thanks to the ever growing team of developers who are contributing to make the MapGuide Open
<p>The MapGuide Team
</body>
</html>
More information about the mapguide-internals mailing list
