[mapguide-internals] Does the Select Within only work for polygon
    Kenneth Skovhede, GEOGRAF A/S
    ks at geograf.dk
    Mon Nov 30 03:22:01 EST 2009
It sounds a like a bug to me.
At least there should not be a "500" error.
Regards, Kenneth Skovhede, GEOGRAF A/S
Buddy Hu skrev:
> Hi There,
> I notice that, the Select within only works for polygon. If there are some other features (such as multipolygon, polyline) selected with polygon, there will be a 500 internal Server Error for selectwithin.php. If there are only multipolygon selected, everything will be cleared after I press the "Done" button.
> I find a description about the "Select Within" in the AJAX Task list home page like this: After you have selected an area, such as a buffer or a polygon on the map, you can select certain features within that area.
> So I want to know, does this Select Within function only work for polygon or buffer? Is this intended?
> If it's no, I want to log a defect for this issue.
> Thanks,
> -Buddy Hu
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
