[mapguide-internals] sudden problem with MapGuideJavaApi
Andreas Morf
a.morf at fkl.ch
Thu Oct 8 08:53:52 EDT 2009
Problem was the PATH-variable added by beta setup:
C:\Programme\OSGeo\MapGuide21\Web\Php
A few days ago I moved the webtier dll's to PHP/ext...
But for me it is not clear why the jre is not able to find dependent dll's
of MapGuideJavaApi.dll even if the JVM-option
"-Djava.library.path=C:\Programme\OSGeo\MapGuide21\Web\Tomcat\bin" was set
for tomcat...
So maybe, also the tomcat/bin should be added to PATH too (if the Java/JSP
Api is installed)
Andreas
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-
> internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Thursday, October 08, 2009 12:04 AM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] sudden problem with MapGuideJavaApi
> I had problems with Java versions and 2.1 installer builds not working
> on
> other peoples' machines; ended up having to go back to 1.5 I think, but
> a
> bit fuzzy. There's a ticket for it somewhere in Trac.
> Jason
> 2009/10/7 Andreas Morf <a.morf at fkl.ch>
> > Thanks for the answers - but i always copied these newly built dll's
> from
> > release/bin to tomcat/bin also the mapguideapi.jar was moved
> accordingly.
> > So I'm really stuck - wonder if it could be an msvcXX.dll matter or a
> > jre-update problem (currently v 1.6_16 is on my dev_machine)...
> > Andreas
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
