[mapguide-internals] MapGuide Trunk vs. which FDO release?
UV uvwild at googlemail.com
Wed Oct 14 10:28:09 EDT 2009
Recording the last FDO revision the build has succeeded with in each
trunk and branch would be a very valuable piece of information. e.g. in
a text file FDOdependency.txt
this could be maintained later by the build server.
Walt Welton-Lair wrote:
> We generally keep MapGuide trunk in sync with FDO trunk.  So if an FDO submission changes some API then MapGuide trunk will usually be updated within say a week.
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Wednesday, October 14, 2009 9:02 AM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] MapGuide Trunk vs. which FDO release?
> i think it's 3.5, could a a version check be added for the fdo version ?
> On Wed, Oct 14, 2009 at 9:22 PM, UV <uvwild at googlemail.com> wrote:
>> I am trying to find some documentation which FDO version the current
>> MapGuide trunk is built against?
>> Currently I get errors from various FDO versions ranging from a missing
>> GetFetchSize to simply empty maps.
>> Any ideas?
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
