[mapguide-internals] MapGuide Trunk vs. which FDO release?
Zac Spitzer zac.spitzer at gmail.com
Wed Oct 14 10:49:21 EDT 2009
or a svn externals ?
On Thu, Oct 15, 2009 at 1:28 AM, UV <uvwild at googlemail.com> wrote:
> Recording the last FDO revision the build has succeeded with in each trunk
> and branch would be a very valuable piece of information. e.g. in a text
> file FDOdependency.txt
> this could be maintained later by the build server.
> Walt Welton-Lair wrote:
>> We generally keep MapGuide trunk in sync with FDO trunk.  So if an FDO
>> submission changes some API then MapGuide trunk will usually be updated
>> within say a week.
>> -----Original Message-----
>> From: mapguide-internals-bounces at lists.osgeo.org
>> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
>> Sent: Wednesday, October 14, 2009 9:02 AM
>> To: MapGuide Internals Mail List
>> Subject: Re: [mapguide-internals] MapGuide Trunk vs. which FDO release?
>> i think it's 3.5, could a a version check be added for the fdo version ?
>> On Wed, Oct 14, 2009 at 9:22 PM, UV <uvwild at googlemail.com> wrote:
>>> I am trying to find some documentation which FDO version the current
>>> MapGuide trunk is built against?
>>> Currently I get errors from various FDO versions ranging from a missing
>>> GetFetchSize to simply empty maps.
>>> Any ideas?
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
