[mapguide-internals] Re: MapGuide RFC 86 is updated.
Leaf Li
leaf.li at autodesk.com
Wed Oct 14 23:17:22 EDT 2009
Hi Zac,
I add two properties PinnedDataConnectionTimeout and PinnedDataConnectionTimerInterval to set time duration in seconds through property 'PinnedDataConnectionTimeout' for when an idle pinned FDO connection is dropped.
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc86
Leaf Li
>changes look good,
>I think we still need a way to flush pinned connections tho, short of
>restarting the server
>z
On Tue, Oct 13, 2009 at 5:39 PM, Leaf Li <leaf.li at autodesk.com> wrote:
> All,
> According to Zac's suggestion, I add two properties into serverconfig.ini to set a limitation of pinned connections per FDO providers in order to avoid exhausting the avaiable FDO connections through pinned connections.
> Can you review it?
> Thanks,
> Leaf Li
More information about the mapguide-internals
