[mapguide-internals] Mapguide 2.1 on Linux
Zac Spitzer
zac.spitzer at gmail.com
Thu Oct 22 00:12:11 EDT 2009
always always check out mapguide by subversion, tar balls are a dead
end IMHO!!!!!
z
On Thu, Oct 22, 2009 at 11:43 AM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> This is a real pain point, which Zac and myself have expressed to Autodesk
> last night at foss4g. I just hope that the cmake work that Helio is doing
> with FDO is replicated (resurrected?) in MapGuide.
> - Jackie
> kernel_panic wrote:
>> Hi
>> I was wondering, is it any release date for mapguide 2.1 on linux?
>> Im asking this because I have been having LOTS of problems trying to
>> install it, FDO simply wont compile unless I use cmake, and that of course
>> forces me to use mapguide trunk (because Im using FDO from trunk),
>> however, the build_oem.sh script fails every single time I run it (trunk
>> version) or when I try the latest stable version (2.0.2) it fails to
>> compile on the final "make" stage when actually building mapguide (you can
>> see the whole story here:
>> http://n2.nabble.com/FDO-Compile-error-libxalan-c-td3772060.html )
>> Some people have suggested me to use mapguide 2.1 beta, but for the last
>> weeks (since I've started with mapguide), I have only seen the
>> mapguideaptinstaller tarball available for download, but not the
>> mapguide2.0.1 tarball.
>> Thanks!
> View this message in context: http://n2.nabble.com/Mapguide-2-1-on-Linux-tp3868957p3869477.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
