[mapguide-internals] Mapguide 2.1 on Linux
Jackie Ng
jumpinjackie at gmail.com
Wed Oct 21 20:43:58 EDT 2009
This is a real pain point, which Zac and myself have expressed to Autodesk
last night at foss4g. I just hope that the cmake work that Helio is doing
with FDO is replicated (resurrected?) in MapGuide.
- Jackie
kernel_panic wrote:
> Hi
> I was wondering, is it any release date for mapguide 2.1 on linux?
> Im asking this because I have been having LOTS of problems trying to
> install it, FDO simply wont compile unless I use cmake, and that of course
> forces me to use mapguide trunk (because Im using FDO from trunk),
> however, the build_oem.sh script fails every single time I run it (trunk
> version) or when I try the latest stable version (2.0.2) it fails to
> compile on the final "make" stage when actually building mapguide (you can
> see the whole story here:
> http://n2.nabble.com/FDO-Compile-error-libxalan-c-td3772060.html )
> Some people have suggested me to use mapguide 2.1 beta, but for the last
> weeks (since I've started with mapguide), I have only seen the
> mapguideaptinstaller tarball available for download, but not the
> mapguide2.0.1 tarball.
> Thanks!
View this message in context: http://n2.nabble.com/Mapguide-2-1-on-Linux-tp3868957p3869477.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
