[mapguide-internals] Server status/Ping API
Bruce Dechant bruce.dechant at autodesk.com
Thu Oct 22 15:35:48 EDT 2009
Hi All,
The existing Server Admin service has the following APIs that are not officially published but are available to use:
GetSiteVersion() - returns the exact MapGuide server version
GetSiteInfo() - returns MapGuide server information and OS information
Both of these require authentication credentials because of the information returned.
I was wondering about adding a new API that would not require authentication credentials.
Example: GetSiteStatus()
I would like it to return the server status as either "Offline" or "Online" as some of the information.
This API could be used as a sort of "ping" if needed.
What other non sensitive information do you think we could include with this API?
Thanks,
Bruce
More information about the mapguide-internals mailing list
