[mapguide-internals] Server status/Ping API
Jason Birch
jason at jasonbirch.com
Sun Oct 25 13:00:19 EDT 2009
I think it would be cool to return API version (2.1, 2.2, etc) as part
of this, but not rev/build.
Would be hesitant to return performance metrics through a non-authenticated api.
Jason
On 2009-10-22, Bruce Dechant <bruce.dechant at autodesk.com> wrote:
> Hi All,
> The existing Server Admin service has the following APIs that are not
> officially published but are available to use:
> GetSiteVersion() - returns the exact MapGuide server version
> GetSiteInfo() - returns MapGuide server information and OS information
> Both of these require authentication credentials because of the information
> returned.
> I was wondering about adding a new API that would not require authentication
> credentials.
> Example: GetSiteStatus()
> I would like it to return the server status as either "Offline" or "Online"
> as some of the information.
> This API could be used as a sort of "ping" if needed.
> What other non sensitive information do you think we could include with this
> API?
> Thanks,
> Bruce
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
