[mapguide-internals] Beta version
Trevor Wekel trevor_wekel at otxsystems.com
Fri Oct 30 09:40:28 EDT 2009
Hello Gabriele,
I am working on providing regular incremental releases for the 2.2 release cycle.  Once the Windows installer build has been ironed out, I may be able to start work on a CentOS 5 based RPM.  However, I cannot dedicate full time to the build project because I also have to generate revenue.
I will post updates to the mapguide-internals list as progress is made.
Sincerely,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Gabriele Monfardini
Sent: October 30, 2009 4:42 AM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Beta version
Dear all,
I would suggest to provide a binary version for GNU/Linux for stable
releases and beta versions.
Which GNU/Linux distribution to support is your choice, the only
requirement is that it should be modern, publicly available for
download and for free.
Actually in order to compile MapGuide 2.x on GNU/Linux is not
sufficient to be a GNU/Linux expert, it is required also to be a
MapGuide codebase expert.
The intersection of these two sets is actually quite small, I suppose.
This because all the software is tightly bundled with all its
dependences, so it is impossible to use the libraries already
available on a modern GNU/Linux distribution.
For example when I added ECW support at my GDAL all my GDAL-enabled
software (eg. QGIS) seamlessly start to work with ECW. The same when a
faster version of something is released. Not not mention when a
security problem is patched.
This is not true for MapGuide, and it's a pity since it uses a lot of
FOSS libraries that are steadily improved over time.
But this would be tolerable if at least recompiling the code was
feasible. That is not.
Since there have been no progresses on easing compilation on GNU/Linux
nor to enable MapGuide to use system-wide libraries (that would be
marvelous but I suppose also a lot of work), at least we need some
binaries.
We cannot afford to spend two weeks just to discover that some bugs
were not yet corrected in the new version (but maybe something old
does not work anymore...).
Regards,
Gabriele Monfardini
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
