[mapguide-internals] Beta version
Gabriele Monfardini
gabrimonfa at gmail.com
Fri Oct 30 12:20:19 EDT 2009
> I am working on providing regular incremental releases for the 2.2 release cycle. Once the Windows installer build has been ironed out, I may be able to start work on a CentOS 5 based RPM.
Good. Thanks
> However, I cannot dedicate full time to the build project because I also have to generate revenue.
Of course.
I also fully understand that GNU/Linux users are a small fraction of
the total users, and that MapGuide developers seem more comfortable
with Windows.
But actually the use of MapGuide under GNU/Linux is so painful that
prevents users (even experienced ones) to contribute to the code. It
is difficult to contribute if the code does not compile nor exists a
binary to play around with.
Removing some of the problems will probably attracts some external
developers, that in turn may help to solve the remaining ones.
Regards,
Gabriele
More information about the mapguide-internals
