[mapguide-internals] Update on builds infrastructure
Trevor Wekel
trevor_wekel at otxsystems.com
Fri Sep 18 09:01:46 EDT 2009
Hi everyone,
After two days of trickery, I have successfully migrated the MapGuide Open Source build environment to VMware vSphere. I decided to do this for a couple of reasons:
VMware is easier to use, more manageable, has integrated high availability and integrated backup capability. I also have nearly three years of experience with VMware ESX technology. From my perspective, it is simply a better fit especially from a multi-platform (Windows/Linux) perspective.
In addition, I am planning to move my VMware virtualization stack to a colocation site. This should improve uptime and reliability of the build environment. It also gives the Project the ability to host additional infrastructure such as a code review tool.
I am going to spend some time working on the build environment over the next few days. The first task on my list is to integrate the installer into the build environment. I will likely ping the list a few times as I work through the process.
Jason - depending on your timelines and availability, I may be able to generate the second beta which was discussed at the PSC meeting last week. I should have something by end of next week if I don't hit too many snags.
Thanks,
Trevor
More information about the mapguide-internals
