[mapguide-internals] Update on builds infrastructure
Jason Birch jason at jasonbirch.com
Sat Sep 19 17:39:06 EDT 2009
I can get it done, but it may be better if I helped setting up an easier way
of pushing the official beta builds in the VM environment :)
IMO, unless we decide to get RFC60 into 2.1 B2, it's going into trunk and
being deferred to 2.2, and this was the main reason I've been holding back.
 I am a bit worried about potential destabilization at this point, and my
preference would be to push RFC60 back.  This is a great addition, and I'd
use it myself, but I don't like the risk.
If UV wants to maintain a sandbox branch of 2.1 that contains the RFC60 work
to allow him to easily pull up fixes from the 2.1 stream for his client, as
well as a sandbox branch of trunk for official integration at 2.2, I'd be
happy with this approach.
Jason
2009/9/18 Trevor Wekel <trevor_wekel at otxsystems.com>
> Hi everyone,
> After two days of trickery, I have successfully migrated the MapGuide Open
> Source build environment to VMware vSphere.  I decided to do this for a
> couple of reasons:
> VMware is easier to use, more manageable, has integrated high availability
> and integrated backup capability.  I also have nearly three years of
> experience with VMware ESX technology.  From my perspective, it is simply a
> better fit especially from a multi-platform (Windows/Linux) perspective.
> In addition, I am planning to move my VMware virtualization stack to a
> colocation site.  This should improve uptime and reliability of the build
> environment.  It also gives the Project the ability to host additional
> infrastructure such as a code review tool.
> I am going to spend some time working on the build environment over the
> next few days.  The first task on my list is to integrate the installer into
> the build environment.  I will likely ping the list a few times as I work
> through the process.
> Jason - depending on your timelines and availability, I may be able to
> generate the second beta which was discussed at the PSC meeting last week.
>  I should have something by end of next week if I don't hit too many snags.
> Thanks,
> Trevor
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
