[mapguide-internals] Documenting
Tom Fukushima tom.fukushima at autodesk.com
Mon Apr 5 13:07:22 EDT 2010
Hi Developers,
We have some money that we would like to put toward documentation (http://producingoss.com/en/producingoss.html#documentation) in order to make the barrier for new developers lower; if you could only pick one or two from the following which would you pick?
Web Tier Component Architecture
Building MapGuide Server and Web Extensions on Linux
Building MapGuide Server and Web Extensions on Windows
Configure Web Extensions on Apache/Linux
Configure Web Extensions on Windows/IIS
Server and Web Tier Debugging HOWTO (Windows and Linux)
Running and maintaining Server and Web Tier Unit Tests
Branches for FDO and MapGuide
Document Render Service HTTP APIs
Other: please specify
This work is already in progress so please respond as soon as you can.
Thanks
Tom
More information about the mapguide-internals mailing list
