[mapguide-internals] RE: Documenting
Tom Fukushima tom.fukushima at autodesk.com
Mon Apr 5 13:10:48 EDT 2010
(Resending with hopefully better formatting than last time)
Hi Developers,
We have some money that we would like to put toward documentation (http://producingoss.com/en/producingoss.html#documentation) in order to make the barrier for new developers lower; if you could only pick one or two from the following which would you pick?
1 Web Tier Component Architecture
2 Building MapGuide Server and Web Extensions on Linux
3 Building MapGuide Server and Web Extensions on Windows
4 Configure Web Extensions on Apache/Linux
5 Configure Web Extensions on Windows/IIS
6 Server and Web Tier Debugging HOWTO (Windows and Linux)
7 Running and maintaining Server and Web Tier Unit Tests
8 Branches for FDO and MapGuide
9 Document Render Service HTTP APIs
10 Other: please specify
This work is already in progress so please respond as soon as you can.
Thanks
Tom
More information about the mapguide-internals mailing list
