[mapguide-internals] RE: Documenting
Martin Morrison
martin.morrison at edsi.com
Mon Apr 5 13:14:36 EDT 2010
Building. You have to build it before you can configure it...
Configure. You have to configure it before you can debug it...
I'm partial to Windows/Apache, but both should be done...Windows first <G>.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom Fukushima
Sent: Monday, April 05, 2010 1:11 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] RE: Documenting
(Resending with hopefully better formatting than last time)
Hi Developers,
We have some money that we would like to put toward documentation (http://producingoss.com/en/producingoss.html#documentation) in order to make the barrier for new developers lower; if you could only pick one or two from the following which would you pick?
1 Web Tier Component Architecture
2 Building MapGuide Server and Web Extensions on Linux
3 Building MapGuide Server and Web Extensions on Windows
4 Configure Web Extensions on Apache/Linux
5 Configure Web Extensions on Windows/IIS
6 Server and Web Tier Debugging HOWTO (Windows and Linux)
7 Running and maintaining Server and Web Tier Unit Tests
8 Branches for FDO and MapGuide
9 Document Render Service HTTP APIs
10 Other: please specify
This work is already in progress so please respond as soon as you can.
Thanks
Tom
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
