[mapguide-internals] Driving Web Tier unit tests from the command
line
Jason Birch
jason at jasonbirch.com
Wed Apr 14 21:18:29 EDT 2010
If not, wouldn't be all that hard to automate with Curl... Some responses
could be validated, but others (e.g. image tests) might need acceptable
range in bytes, etc.
Jason
On 14 April 2010 17:05, Jackie Ng wrote:
> Hi All,
> Is there a way to drive the web tier unit tests from the command line? I'd
> like to quickly verify that an installer build is firing on all cylinders.
> I know that the server application has the unit tests built in, but what
> about the web tier?
> - Jackie
> http://n2.nabble.com/Driving-Web-Tier-unit-tests-from-the-command-line-tp4904831p4904831.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
