[mapguide-internals] Driving Web Tier unit tests from the
command line
Trevor Wekel
trevor_wekel at otxsystems.com
Wed Apr 14 22:43:01 EDT 2010
Hi Jackie,
"php runtests.php"
Take a look as pages 23 and 24 of http://mapguide.osgeo.org/sites/mapguide.osgeo.org/files/BuildingAndConfiguringMGOSOnWindows.pdf.
This information is a bit out of date but it might be close enough to be usable. The web tier unit tests only cover portions of the PHP Web Extensions API and portions of the HTTP API. They are certainly not exhaustive and they completely miss .Net and Java.
I have been thinking about doing a rewrite of the web tier unit tests to make them more easily maintainable. The current system works but it is tricky to maintain. A set of .Net/PHP/Java web pages with data supplied by backend xml documents would probably be a better fit for Subversion, more transparent, and easier to maintain. Invocation of the web pages could be performing using Curl or maybe some form of combined unit test / load test harness.
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: April 14, 2010 7:18 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Driving Web Tier unit tests from the command line
If not, wouldn't be all that hard to automate with Curl... Some responses
could be validated, but others (e.g. image tests) might need acceptable
range in bytes, etc.
Jason
On 14 April 2010 17:05, Jackie Ng wrote:
> Hi All,
> Is there a way to drive the web tier unit tests from the command line? I'd
> like to quickly verify that an installer build is firing on all cylinders.
> I know that the server application has the unit tests built in, but what
> about the web tier?
> - Jackie
> http://n2.nabble.com/Driving-Web-Tier-unit-tests-from-the-command-line-tp4904831p4904831.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
