[mapguide-internals] Re: Getting closer with 64 bit installer
Jackie Ng
jumpinjackie at gmail.com
Fri Jul 2 03:29:58 EDT 2010
I've tried a variation of the following registry hack described here:
http://www.teachout.com/Blog/tabid/165/EntryId/246/Windows-Environment-Variables-Overrides-for-IIS6.aspx
I set MENTOR_DICTIONARY_PATH this way after an IIS configuration install and
it was able to pick up the env var and not blow up when I load the AJAX
viewer.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Getting-closer-with-64-bit-installer-tp5228366p5246694.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
