[mapguide-internals] Re: Getting closer with 64 bit installer
Trevor Wekel
trevor_wekel at otxsystems.com
Fri Jul 2 11:56:14 EDT 2010
Hi Jackie,
This is a great find! Do you have time to implement the environment variable overrides for IIS? If so, I will assign Ticket #1388 to you. Otherwise, I will close the ticket saying that a workaround exists (reboot the machine).
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: July 2, 2010 1:30 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Re: Getting closer with 64 bit installer
I've tried a variation of the following registry hack described here:
http://www.teachout.com/Blog/tabid/165/EntryId/246/Windows-Environment-Variables-Overrides-for-IIS6.aspx
I set MENTOR_DICTIONARY_PATH this way after an IIS configuration install and
it was able to pick up the env var and not blow up when I load the AJAX
viewer.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Getting-closer-with-64-bit-installer-tp5228366p5246694.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
