[mapguide-internals] Re: Getting closer with 64 bit installer
Jason Birch
jason at jasonbirch.com
Fri Jul 2 12:43:37 EDT 2010
Personally, I'd prefer to stay with the requirement for a reboot rather than
adding yet another place to look for configuration settings.
The real fix for this is to allow the dictionary path to be read from the
webconfig and serverconfig files, falling back to the environment variable
if it exists.
Jason
On 2 July 2010 08:56, Trevor Wekel wrote:
> This is a great find! Do you have time to implement the environment
> variable overrides for IIS? If so, I will assign Ticket #1388 to you.
> Otherwise, I will close the ticket saying that a workaround exists (reboot
> the machine).
More information about the mapguide-internals
