[mapguide-internals] Getting closer with 64 bit installer
Jason Birch jason at jasonbirch.com
Sat Jul 3 12:33:16 EDT 2010
Perhaps they hard-code the location of cs-map binaries under common
files or something?
Just because we can, doesn't mean we should. Another configuration
point means more complexity in troubleshooting, more stuff to clean up
pre/post install, and more difficulty supporting SxS installs.
Jason
On 2010-07-02, Jackie Ng <jumpinjackie at gmail.com> wrote:
> I cite the MGE installer, they *must* be using tricks like this to avoid a
> reboot (I have never needed to reboot instlling MGE, ever!).
> If they can do it, so can we.
> - Jackie
> http://osgeo-org.1803224.n2.nabble.com/Getting-closer-with-64-bit-installer-tp5228366p5250387.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
