[mapguide-internals] Getting closer with 64 bit installer
Trevor Wekel trevor_wekel at otxsystems.com
Sun Jul 4 10:02:36 EDT 2010
Yes.  A hard coded registry setting is checked if MENTOR_DICTIONARY_PATH is not set.
http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp#L183
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: July 3, 2010 10:33 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Getting closer with 64 bit installer
Perhaps they hard-code the location of cs-map binaries under common
files or something?
Just because we can, doesn't mean we should. Another configuration
point means more complexity in troubleshooting, more stuff to clean up
pre/post install, and more difficulty supporting SxS installs.
Jason
On 2010-07-02, Jackie Ng <jumpinjackie at gmail.com> wrote:
> I cite the MGE installer, they *must* be using tricks like this to avoid a
> reboot (I have never needed to reboot instlling MGE, ever!).
> If they can do it, so can we.
> - Jackie
> http://osgeo-org.1803224.n2.nabble.com/Getting-closer-with-64-bit-installer-tp5228366p5250387.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
