[mapguide-internals] Re: Getting closer with 64 bit installer
Jason Birch jason at jasonbirch.com
Tue Jul 6 03:19:54 EDT 2010
The installer conditionals are already really complicated, and I worry that
adding more special cases will increase our risk and the complexity of
troubleshooting user installs.
I do agree that requiring a reboot is silly, but I also don't really see it
as a huge problem.  For development platforms, rebooting isn't a big deal,
and for production platforms the extra time for a reboot isn't much of an
issue considering that you're likely doing this no more than twice a year,
and have already scheduled downtime for cold backup, uninstall, re-install.
 Yes, it's not compliant with Windows best practices, and it's ugly, but the
cost to the end user is relatively low.
What I would like to see is an increased isolation from system / registry
settings with the following:
- MapGuide server and web tier pulling CS-Map path from an ini file setting
(no need for env var setting or reboot)
- PHP running as FastCGI, picking up its INI settings from installation
directory (no more need for PHP registry key)
Unfortunately, I don't have money to put where my mouth is, and both are too
much work to get into 2.2 even if I did.
Regardless, this isn't really a sticking point for me, I just think the
costs of removing the reboot requirement from this one configuration (I'm
still surprised it isn't more widespread) are not worth the benefit.
Jason
On 5 July 2010 23:15, Jackie Ng wrote:
> Mind you, this only affects one configuration (Windows, 64-bit, IIS) out of
> the many possible different install configurations you could have in
> MapGuide.
> This is 2010, we shouldn't have to reboot for petty things like this.
More information about the mapguide-internals mailing list
