[mapguide-internals] MapGuide 2.2 RC1 Release Readiness
Zac Spitzer zac.spitzer at gmail.com
Sat Jul 10 20:36:40 EDT 2010
out of bounds tile requests are rendered and persisted
http://trac.osgeo.org/mapguide/ticket/1308
needs discussion, but shouldn't be a blocker for 2.2 at all
Apache crashes under load
http://trac.osgeo.org/mapguide/ticket/1278
is a critical error and is needed for 2.2 IMHO
MapGuide unresponsive using GDAL provider (related to ticket #462)
http://trac.osgeo.org/mapguide/ticket/1196
is a long standing bug which Trevor is going to look at, but given the
amount of work he is doing on other 2.2 issues, we shouldn't block on this
Right button context menu doesn't work in Opera or Chrome
http://trac.osgeo.org/mapguide/ticket/1274
I'll have a look into this one today
Avoiding login window in an application using flexible fusion weblayout
http://trac.osgeo.org/mapguide/ticket/1021
I will ping Mike for his thoughts about this
z
On 11 July 2010 04:30, Jason Birch <jason at jasonbirch.com> wrote:
> Trevor, would it be possible for you to put up an interim latest build
> of both x86 and x64 windows installers for some testing?
> I can definitely see some of those tickets getting pushed
> post-release.  Others are a bit troubling (SQL Server connectivity,
> etc) and I'm going to see if I can reproduce.
> First thing I'm going to do though is play with the benchmark data to
> see if I can get some initial styling set up.
> Jason
 On 2010-07-10, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
>> Hi everyone,
>> I have put together a release readiness page for 2.2 RC1.  I believe the
>> builds and installers are in relatively good shape.  And we have a stack of
>> defects to consider for the release
>> http://trac.osgeo.org/mapguide/wiki/ReleaseReadiness22RC1#Defects
>> Regards,
>> Trevor
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
