[mapguide-internals] Re: Getting closer with 64 bit installer
Jason Birch
jason at jasonbirch.com
Wed Jul 14 02:47:22 EDT 2010
I like that solution Hugues.
On 9 July 2010 06:37, Hugues Wisniewski wrote:
> So, instead of having the MgCoordinateSystemCatalog hold the logic to get
> to the right path value, the client application could do that job and pass
> the path value to the API directly
> One solution would be to give the path to the MgCoordinateSystemFactory
> object when it is created.
> The default constructor would choose the default path value while something
> like the following would change that default path:
> MgCoordinateSystemFactory::MgCoordinateSystemFactory(STRING sPath)
More information about the mapguide-internals
