[mapguide-internals] RFC 103 is cancelled
Christine Bao
Christine.Bao at autodesk.com
Thu Jul 15 03:37:05 EDT 2010
Hi all,
After double check with CS map team, they will improve library to support full set of EPSG codes, and there is no need to customize EPSG code in configuration files anymore. The RFC 103 (Client needs to get WMS/WFS config info) https://trac.osgeo.org/mapguide/wiki/MapGuideRfc103 has been cancelled.
Thanks & regards,
Christine
More information about the mapguide-internals
