[mapguide-internals] RFC 103 is cancelled
Zac Spitzer
zac.spitzer at gmail.com
Thu Jul 15 03:43:04 EDT 2010
Hi Christine,
Can you move the bold cancelled reasoning to the top of the RFC?
z
On 15 July 2010 17:37, Christine Bao <Christine.Bao at autodesk.com> wrote:
> Hi all,
> After double check with CS map team, they will improve library to support full set of EPSG codes, and there is no need to customize EPSG code in configuration files anymore. The RFC 103 (Client needs to get WMS/WFS config info) https://trac.osgeo.org/mapguide/wiki/MapGuideRfc103 has been cancelled.
> Thanks & regards,
> Christine
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
