[mapguide-internals] Windows 7 - using program data folders
rather than program files
Bruce Dechant
bruce.dechant at autodesk.com
Tue Jul 20 16:07:35 EDT 2010
Zac,
Good suggestion.
This would require a code change to the server in order to understand the %appdata% as currently the paths inside the serverconfig.ini file do not support that directive.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Sunday, July 18, 2010 8:21 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Windows 7 - using program data folders rather than program files
With the all the new fangled security on windows 7, it's rather
annoying to have to
change the permissions on the packages folder to be able to import a package
via mapadmin
http://forum.notebookreview.com/windows-os-software/348462-unable-copy-folders-into-program-files.html
I would suggest that the following folders belong in program data
Logs
Packages
Repositories
Schema
Temp
Wfs
Wms
serverconfig.ini and providers.xml also present issues here but that
would involve
more fundamental underlying code changes
can %appdata% type paths be used in serverconfig.ini?
z
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
