[mapguide-internals] Review RFC 108 - support Watermark
Trevor Wekel
trevor_wekel at otxsystems.com
Fri Jul 30 14:53:38 EDT 2010
Hi Buddy,
I agree with Jason and Jackie.
We should be using and referencing a SymbolDefinition resource in the new "WaterMark" resource. This provides better flexibility for defining the watermark. The SymbolDefinition is a XML document. Our end users can create and customize this by hand. A DWF-based watermark could lead to vendor lock in since DWF editing support is less common. As Jackie mentioned, Maestro does not support DWF.
It might be worthwhile to investigate how SymbolDefinition can support watermarking. For example, the SymbolDefinition "Image" can be an inline base64 encoded PNG image with the width and height defined in mm and the x and y coordinates in symbol space also defined in mm. I suspect the "WaterMark" resource may only need to specify where to put the symbol (top right, bottom left, etc - ie, define a "point feature" for the symbol) and then reference the SymbolDefinition.
To support WMS, the LayerDefinition will need to support a "WaterMark" reference. Our WMS implementation knows nothing about "maps" so the watermark information must be contained in the LayerDefinition. Maestro, MapGuide Studio, and AutoCAD Map will need to write this information as part of "WMS publishing".
Support for multiple watermarks on the same map would also be good. This is hinted at by the "WaterMarkList" in MgMap. Not all data served by MapGuide will come from the same source. Only specific data sources / layers would require the map to be watermarked. The complete "map" watermark could be the collection of the defined watermarks from the MapDefinition and all referenced LayerDefinitions. For example, if Autodesk was serving a Navteq layer on the web, the MapDefinition could define "(c) Autodesk" as text and Navteq layer could define the "(c) Navteq" so you'd end up with
(c) Autodesk
(c) Navteq
Watermarked in the final output image. This is a bit strange but it might help customers comply with data licensing requirements and still give them the ability to "mark" everything they serve with their own brand.
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: July 30, 2010 9:42 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Review RFC 108 - support Watermark
I agree with Jackie's comment about not using DWF.
Is there any way that we could use the SymbolDefinition (I think;
whatever advanced stylization is) resource instead of creating a new
one for watermark? There would be some constraints like device space
only, and the MapDefinition would be responsible for defining
placement.
I really don't like the idea of updating the LayerDefinition headers
when the MapDefinition is changed. Layer to Map can be a Many:Many
relationship. I think that the watermark information should be
manually maintained on each layer as part of the WMS metadata UI, like
the rest of the WMS information. This is a client implementation
detail though I think, as it sounds like you're just talking about
expanding the LayerDefinition metadata rather than walking the Layer->
Map dependency at render time.
Jason
On 2010-07-30, Buddy Hu <Buddy.Hu at autodesk.com> wrote:
> Hi all,
> Please review the RFC 108 - support Watermark.
> Link: https://trac.osgeo.org/mapguide/wiki/MapGuideRfc108
> Please feel free to add your comments!
> Regards,
> -Buddy
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
