[mapguide-internals] MG CreateSession
Jason Birch jason at jasonbirch.com
Fri Jun 4 04:36:37 EDT 2010
I'm not sure if there's a way of fixing this. The IP address that my
host knows itself as is not the same as the ip address the world sees.
Internally, it's sitting in a local subnet, with an external NAT IP
assigned at the firewall.
On 2010-05-31, Haris Kurtagic <haris at sl-king.com> wrote:
> Hi,
> I ran into issue with Server CreateSession
> command. CreateSession will embed IP of server into session id. Issue I ran
> into was that embedded IP would be 127.0.0.1 ( if not changed
> in serverconfig.ini) regardless that server command was executed trough
> another machine.
> So, for example If I ran GeoREST on one machine and execute command to MG
> server which is on another IP  (e.g. 192.168.0.3), MG server would return
> 127.0.0.1 in session id (should be 192.168.0.3 ). Then that sessionid would
> be invalid and further commands would fail which use the sessionid.
> I know that solution would be to set IP in serverconfig but as MG would
> accept CreateSession command on one IP address it would be nice that it
> returns the same IP in session id
> Haris
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
