[mapguide-internals] MG CreateSession
Haris Kurtagic
haris at sl-king.com
Fri Jun 4 04:46:20 EDT 2010
It is not important what IP it is. It would be important that server
returns IP which was used to connect to that server at first place.
For example you could have current web extension talking to internal
MG server on machine e.g. 192.168.0.3.
Server would accept that connection and command but when creating
session id would use default 127.0.0.1 to pack inside session id
string.
Next command using that session id would fail.
To make this scenario work you would need to set in server config IP
(192.168.0.3) of machine to be used in session id.
It would be much more cleaner that server would simple use IP of TCP
connection which was used to execute create session command and then
pack that IP into session id string.
Haris
On Fri, Jun 4, 2010 at 10:36 AM, Jason Birch <jason at jasonbirch.com> wrote:
> I'm not sure if there's a way of fixing this. The IP address that my
> host knows itself as is not the same as the ip address the world sees.
> Internally, it's sitting in a local subnet, with an external NAT IP
> assigned at the firewall.
> On 2010-05-31, Haris Kurtagic <haris at sl-king.com> wrote:
>> Hi,
>> I ran into issue with Server CreateSession
>> command. CreateSession will embed IP of server into session id. Issue I ran
>> into was that embedded IP would be 127.0.0.1 ( if not changed
>> in serverconfig.ini) regardless that server command was executed trough
>> another machine.
>> So, for example If I ran GeoREST on one machine and execute command to MG
>> server which is on another IP (e.g. 192.168.0.3), MG server would return
>> 127.0.0.1 in session id (should be 192.168.0.3 ). Then that sessionid would
>> be invalid and further commands would fail which use the sessionid.
>> I know that solution would be to set IP in serverconfig but as MG would
>> accept CreateSession command on one IP address it would be nice that it
>> returns the same IP in session id
>> Haris
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
