[mapguide-internals] The coordinate system initialization failed
Eduardo Sereno edu at gismedia.pt
Mon Jun 7 15:34:08 EDT 2010
Hi all.
Can someone please help. I have installed mapguide os 2.2.0 in a fresh
ubuntu 9.10 machine (timezone Europe/lisbon), with the new released script.
Everything went fine until I try to start the server.
If I use ./mgserver I receive this message
(3018566496) The coordinate system initialization failed.
Mentor path is correct. Everithing seems fine, but server stops immediately.
If I use ./mgserver.sh I receive
(3018316640) Server starting...
(3018316640) Mentor Coordinate System Library
(3018316640) Server started.
And I am able to connect to the server.
What Am I missing?
Thanks in advanced.
Best regards
Edu
View this message in context: http://osgeo-org.1803224.n2.nabble.com/The-coordinate-system-initialization-failed-tp5150715p5150715.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
