[mapguide-internals] The coordinate system initialization failed
Trevor Wekel
trevor_wekel at otxsystems.com
Mon Jun 7 19:07:38 EDT 2010
Hi Edu,
The mgserver.sh script sets some environment variables before running the mgserver executable. If you add the variables to your environment, the mgserver executable should work.
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Eduardo Sereno
Sent: June 7, 2010 1:34 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] The coordinate system initialization failed
Hi all.
Can someone please help. I have installed mapguide os 2.2.0 in a fresh
ubuntu 9.10 machine (timezone Europe/lisbon), with the new released script.
Everything went fine until I try to start the server.
If I use ./mgserver I receive this message
(3018566496) The coordinate system initialization failed.
Mentor path is correct. Everithing seems fine, but server stops immediately.
If I use ./mgserver.sh I receive
(3018316640) Server starting...
(3018316640) Mentor Coordinate System Library
(3018316640) Server started.
And I am able to connect to the server.
What Am I missing?
Thanks in advanced.
Best regards
Edu
View this message in context: http://osgeo-org.1803224.n2.nabble.com/The-coordinate-system-initialization-failed-tp5150715p5150715.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
