[mapguide-internals] Re: The coordinate system initialization
failed
Zac Spitzer
zac.spitzer at gmail.com
Tue Jun 8 20:40:26 EDT 2010
that simply means that the fdo provider can't load the postgres libaries
which version of postgres libaries have you got installed?
if you run ld on the fdo provider files, it will tell you what files
it's missing
On 9 June 2010 10:37, Eduardo Sereno <edu at gismedia.pt> wrote:
> Thanks Trevor,... but now I have a new problem.
> When I try to connect Maestro to my Postgresql/postgis database I keep
> receivind this:
> CLNT_8_UNABLE_TO_LOAD_LIBRARY
> Can someone please help? I'm driving crazy...
> Regards
> Edu
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/The-coordinate-system-initialization-failed-tp5150715p5156122.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
