[mapguide-internals] Re: The coordinate system initialization failed
Zac Spitzer zac.spitzer at gmail.com
Tue Jun 8 20:44:02 EDT 2010
actually, on second thoughts, i think that might be an oracle
specific error..... try what i suggested first, but you might need
to install the oracle instant client as well...
if it is oracle, that's a bad bug
On 9 June 2010 10:40, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> that simply means that the fdo provider can't load the postgres libaries
> which version of postgres libaries have you got installed?
> if you run ld on the fdo provider files, it will tell you what files
> it's missing
> On 9 June 2010 10:37, Eduardo Sereno <edu at gismedia.pt> wrote:
>> Thanks Trevor,... but now I have a new problem.
>> When I try to connect Maestro to my Postgresql/postgis database I keep
>> receivind this:
>> CLNT_8_UNABLE_TO_LOAD_LIBRARY
>> Can someone please help? I'm driving crazy...
>> Regards
>> Edu
>> View this message in context: http://osgeo-org.1803224.n2.nabble.com/The-coordinate-system-initialization-failed-tp5150715p5156122.html
>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
More information about the mapguide-internals mailing list
