[mapguide-internals] Re: The coordinate system initialization
failed
Jack Lee
jack.lee at sympatico.ca
Tue Jun 8 21:00:29 EDT 2010
The problem shouldn't be related to Oracle. When the provider shared
library fails to load, that message is issued.
Use ldd -r to show what libraries or symbols are missing.
On 6/8/2010 8:44 PM, Zac Spitzer wrote:
> actually, on second thoughts, i think that might be an oracle
> specific error..... try what i suggested first, but you might need
> to install the oracle instant client as well...
> if it is oracle, that's a bad bug
> On 9 June 2010 10:40, Zac Spitzer<zac.spitzer at gmail.com> wrote:
>> that simply means that the fdo provider can't load the postgres libaries
>> which version of postgres libaries have you got installed?
>> if you run ld on the fdo provider files, it will tell you what files
>> it's missing
>> On 9 June 2010 10:37, Eduardo Sereno<edu at gismedia.pt> wrote:
>>> Thanks Trevor,... but now I have a new problem.
>>> When I try to connect Maestro to my Postgresql/postgis database I keep
>>> receivind this:
>>> CLNT_8_UNABLE_TO_LOAD_LIBRARY
>>> Can someone please help? I'm driving crazy...
>>> Regards
>>> Edu
>>> View this message in context: http://osgeo-org.1803224.n2.nabble.com/The-coordinate-system-initialization-failed-tp5150715p5156122.html
>>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
More information about the mapguide-internals
