[mapguide-internals] RE: RFC Review - RFC 96: QuickPlot
	solution 	for both Ajax and Fusion viewers
    Mars Wu
    mars.wu at autodesk.com
    Mon Jun 21 04:02:24 EDT 2010
Hi Zac, Ivan and Jackie,
Thank you very much for the comments.
I think I made a mistake by reading Ivan's question "Save as DWG" as "Save as DWF"... sorry for the mistake.
>From my point of view, "Saving as DWF" makes sense for a "Plot" related function, while saving as "DWG" or "DXF" is beyond the "plot" topic.
Thanks,
Mars
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Monday, June 21, 2010 3:23 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] RE: RFC Review - RFC 96: QuickPlot solution for both Ajax and Fusion viewers
any thoughts on using DXF? it's a text format after all, an not so subject to version-itis
2010/6/21 Ivan Miličević <Ivan.Milicevic at supranet.hr>:
> That's too bad. Autodesk should be more flexibile here, I'm sure that they could find a way to share toolkit only to the mapguide users.
> Thank's for the answer, when I develop such a function I wil provide it to the cummunity.
> Thank's again.
> Jackie Ng
> Sent: Monday, June 21, 2010 9:11 AM
> To: mapguide-internals at lists.osgeo.org
> Subject: [mapguide-internals] RE: RFC Review - RFC 96: QuickPlot
> The problem is strictly a licensing one.
> Writing DWGs files requires the RealDWG toolkit, which is a proprietary SDK which is obviously incompatible with MapGuide Open Source.
> That doesn't stop you from attempting such a solution yourself (if you have a RealDWG license), it's just not possible to integrate such functionality into an Open Source project.
> - Jackie
> http://osgeo-org.1803224.n2.nabble.com/RFC-Review-RFC-96-QuickPlot-sol
> ution-for-both-Ajax-and-Fusion-viewers-tp5173317p5203146.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
