[mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles
	using Style Order
    Zac Spitzer
    zac.spitzer at gmail.com
    Wed Jun 23 04:58:44 EDT 2010
incidently, this came up as an issue with the FOSS4G WMS shootout
rendering criteria
http://wiki.osgeo.org/wiki/Benchmarking_2010/How_to_get_some_sample_data#Rendering_notes
On 15 October 2009 19:58, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> This all started with talking about a very specific use case here,
> the rendering of road network polylines, they are extremely common where i live
> if a provider doesn't support ordering and the user needs to they can switch
> to a provider which does, solved
> if a dataset doesn't have that ordering column, they can always
> massage the data
> or use separate layers, no change from current
> As Traian said before, ordering is perhaps the most user friendly approach
> and is a nice logical feature to have
> Making this easy for users is going to aid MapGuide Adoption
> i think it's also the least effort?
> z
> On Tue, Sep 15, 2009 at 3:49 AM, Traian Stanev
> <traian.stanev at autodesk.com> wrote:
>>> Another thing to consider is that ordering by the data values doesn't
>>> guarantee the required results unless the user has a field with values that
>>> generate the correct order. They may have to modify their data by adding a
>>> column to get the desired results? What if they can't modify the source data
>>> then they may have to use a computed field which would be a further
>>> performance hit.
>> Yes, that's true, and I also mentioned this in my last paragraph. The ordering solution only works if there is a column whose sort order would be equivalent to draw order. If there is no such column, I would recommend the multiple layers approach.
>>> I also find that customers generally don't separate each style condition
>>> into separate layers (effectively a data filter) as this can result in too
>>> many layers to manage.
>> Again, it depends on the data. In some cases using multiple layers would be better than using ordering and vice versa. The third option, of using multiple style definitions with rendering passes is more or less equivalent to the multiple layers option. I don't think "too many layers" is an objective argument to not use this workaround in cases where there is no other way to fix draw order -- unless you have an idea for another approach that doesn't have this disadvantage.
>>> Another problem with using data sorting as an approach is that many
>>> customers use SDF for performance and this doesn't support ordering
>>> currently. I would argue that if this is the route taken than an enhancement
>>> to the SDF provider is needed to support ordering. It doesn't make sense
>>> that the primary provider in MapGuide can't be used.
>> For performance sensitive applications, the SQLite provider is a good alternative to SDF (it's generally faster and can do ordering).
>> Traian
>>> -----Original Message-----
>>> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-
>>> bounces at lists.osgeo.org] On Behalf Of Dave Wilson
>>> Sent: Monday, September 14, 2009 1:32 PM
>>> To: MapGuide Internals Mail List
>>> Subject: RE: [mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles
>>> using Style Order
>>> performance hit.
>>> Just a few more thoughts to consider before choosing this option.
>>> Dave
>>> bounces at lists.osgeo.org] On Behalf Of Traian Stanev
>>> Sent: Monday, September 14, 2009 10:43 AM
>>> using Style Order
>>> Using ordering to fix draw order is fine as long as you keep in mind that it
>>> is not necessarily faster than using one of the two other workarounds
>>> described in the RFC. Some variables at play are the cost of an extra query
>>> per different style you want to use and the cost of ordering, which involves
>>> reading the features at least once inside the provider in order to sort them
>>> before returning them.
>>> Another important variable is that it is significantly cheaper to evaluate
>>> style filters when you have one possible style for the whole layer (like in
>>> workaround 1) -- if you have 10 possible styles in the layer, the rendering
>>> engine will have to evaluate on average 5 filters before finding the right
>>> one, which is also fairly expensive. But then, the total cost of filter
>>> evaluations as compared to the cost of an extra FDO query depends on how
>>> many features on average are returned by the query.
>>> So, to me, using ordering to fix draw order is not a clear cut winner from
>>> performance standpoint, but I guess from user standpoint it's the easiest
>>> option to implement, as long as you have an attribute value whose order is
>>> strictly equivalent to draw order.
>>> Traian
>>> internals-
>>> > bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
>>> > Sent: Friday, September 11, 2009 10:15 PM
>>> > Subject: Re: [mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles
>>> > using Style Order
>>> > following up on the PSC discussion about this RFC
>>> > http://trac.osgeo.org/mapguide/wiki/PscMeeting09-10-2009
>>> > it was noted that this RFC depends on FDO RFC 40
>>> > http://n2.nabble.com/RFC-40-Add-standardized-ordering-support-
>>> td3223241.html
>>> > to which Orest replied that this is already part of the FdoISelect API
>>> > given that it seems that maybe RFC 40 is therefore potentially redundant
>>> > and it's only a question there whether the given FDO provider in use
>>> > supports
>>> > ordering, i guess we can focus back on the core of the RFC?
>>> > It seems that everyone is happy with approach of pre-ordering of data
>>> > and adding support to a layer def for defining which column to order by
>>> > the implementation would be as follows?
>>> > 1. add ordering to the layer definition
>>> > 2. add support to apply the ordering, throwing an exception when
>>> > the provider doesn't support it
>>> > thoughts?
>>> > z
>>> > On Thu, Jul 9, 2009 at 2:08 AM, Traian Stanev
>>> > > The draw priority of labels depends on the draw order of your layers.
>>> > Labels for the topmost layers get priority. So you have to make sure that
>>> > the layer with the major highways draws on top of the layer containing the
>>> > rest of the roads -- this assumes that you have one layer for major and
>>> one
>>> > layer for secondary roads. I'm probably repeating what was already said --
>>> > this is the approach that will work with the current implementation, but
>>> it
>>> > has the overhead of having to do a data query for each of the layers. The
>>> > alternative is to pre-order the data so that your major roads come last in
>>> > your SHP file (or whatever data source you are using).
>>> > > If all you are worried about is label draw order, it will probably make
>>> > sense to ask for something like "label priority" setting for each theme
>>> rule,
>>> > which would give you control over which labels draw and which don't
>>> > regardless of the underlying theme/layer/filter ordering.
>>> > > Traian
>>> > internals-bounces at lists.osgeo.org] On Behalf Of Scott Hameister
>>> > > Sent: Wednesday, July 08, 2009 11:34 AM
>>> > > To: 'MapGuide Internals Mail List'
>>> Styles
>>> > using Style Order
>>> > > That's a little clearer...I thought I had seen a comment (which I cant
>>> > find) that multiple layers with filters ran more efficiently than a them
>>> > with the same number of rules...Thats why I was utterly confused...
>>> > > I assumed Creating the image from the objects would be much faster when
>>> > things weren't stylized one line at a time differing from one line to the
>>> > next, but instead stylized in groups...especially with end matching,
>>> complex
>>> > line styles and the like...I will admit it sounds like my idea is a bad
>>> one,
>>> > even tho it would take care of objects rendering as intended, it sounds
>>> like
>>> > it would have had no effect on a labeling hierarchy anyways, which is what
>>> > was my primary concern....I wanted Major HWYS...i.e. Upper Level rules to
>>> > take labeling precedence over Local roads(lower Level rules).
>>> > > I'll Leave it to the pros...I wanted to make sure I understood the whys
>>> > before I gave up the fight...Thanks guys...Youve all enlightened me.
>>> > > PS has there been any discussions about creating a HWY/Symbol Shield
>>> > interface in Maestro...or has anyone seen a tool I could give customers
>>> for
>>> > doing this easier than teaching them XML?
>>> > internals-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
>>> > > Sent: Wednesday, July 08, 2009 10:15 AM
>>> Styles
>>> > using Style Order
>>> > > Pushing the filtering to the side of the database will not make the
>>> > filtering any faster.
>>> > > In the cases of the fastest current data providers (SDF and SHP), the
>>> > filtering code is the same as the filtering code used by MapGuide to
>>> execute
>>> > the filter, so you gain nothing -- the data provider will have to do the
>>> > filter linearly across all the features in order to return the 15 features
>>> > your filter is looking for.
>>> > > In the case of other (slower) data providers, the overhead of the
>>> multiple
>>> > select commands (as opposed to a single select like the code does now)
>>> will
>>> > kill you, even if the underlying database is indexing the columns that
>>> your
>>> > filter is based on. There is a high overhead for selects, since each one
>>> > will also do a spatial query, and there are other overheads as well.
>>> > > Unless you pre-compute the bottleneck away by reordering the original
>>> data,
>>> > it will always be there, just in a different place.
>>> > > Traian
>>> > > Sent: Wednesday, July 08, 2009 11:08 AM
>>> Styles
>>> > using Style Order
>>> > > Lets assume say 15 rule categories on 10,000 objects...
>>> > > Walt not trying to be a pest...I understand your math...But doesn t the
>>> > current method by iterating through every record individually "N=10,000"
>>> as
>>> > the outer loop...thus make 10,000 selections Which Should always be more
>>> > than the number of "M" rules? (M=15) If the overhead is in Selecting
>>> wouldn
>>> > t selecting 15 be a better number than 10,000...
>>> > > The stylization is done without a filter because its pre filtered, so
>>> > shouldn t that also save on time as well?
>>> > internals-bounces at lists.osgeo.org] On Behalf Of Walt Welton-Lair
>>> > > Sent: Wednesday, July 08, 2009 12:33 AM
>>> Styles
>>> > using Style Order
>>> > > Assume a themed soil layer with M rules being applied against a dataset
>>> > with N features.  You're wondering how that would perform against M layers,
>>> > each using a filter corresponding to one of the rules, and each against
>>> the
>>> > same dataset.
>>> > > In the first scenario we make one FDO select operation and it returns
>>> all
>>> > the features.  That's O(N) work.  We also make O(M*N) filter evaluations
>>> in
>>> > the stylization code.
>>> > > In the second scenario we make M FDO select operations (each with the
>>> > appropriate filter) and each returns a subset of the features.  Unless you
>>> > have a simple filter that the provider can efficiently handle it's still
>>> > going to be O(N) work per select operation.  Since FDO applies the filter
>>> we
>>> > don't do any filter evaluations during stylization.
>>> > > For the two scenarios many things are the same:
>>> > > * the overall number of features processed by the server
>>> > > * the overall amount of data sent back from the provider
>>> > > * the overall filtering work of O(M*N)
>>> > > The difference in the scenarios is the number of FDO select operations:
>>> 1
>>> > versus M.  Each select operation has overhead (e.g. latency for a dataset
>>> > remote from the MG server, opening the data connection, etc.) and that IMO
>>> > is what will cause the second scenario to be slower.  Of course it will
>>> vary
>>> > with the provider and whether the dataset is local to the MG server.  In
>>> > general it's important to keep the number of data requests low.
>>> > > Obviously the first scenario - which is how MG currently works - doesn't
>>> > give you the desired draw order behavior, while the second scenario
>>> > does.  With the data massaging workaround you have only one FDO
>>> > select.  It's the same as the first scenario, but now the FDO select
>>> returns
>>> > the features in the order you want.
>>> > > Why don't you do a test for us (and prove me wrong :-]).  Try out the
>>> two
>>> > scenarios for one of your themed layers, measure the performance, and
>>> share
>>> > the results.
>>> scotth at mpowerinnovations.com
>>> > > Sent: Wednesday, July 08, 2009 12:24 AM
>>> > > To: Zac Spitzer; MapGuide Internals Mail List
>>> Styles
>>> > using Style Order
>>> > > Im missing something big here...why cant filtering like happens on
>>> > individual layers work? I only use themes when individual layers with
>>> > filters is overwhelming like soils, or to avoid grouping for legend
>>> > reasons...id guess 80 pct of users use a wizard to theme, but 20 pct use
>>> > advanced rules...i like a pre-cooker..but wht cant the default action be
>>> to
>>> > itterate thru the rules as an outside query than to itterate thru geometry
>>> > individually? Im trying to understand a pre cooker on live data..or often
>>> > updated load procedures..fills in a column called rule..and puts in a 1
>>> for
>>> > rule 1?...and we apply my pre mentioned filter..why not making filter
>>> > default instead of geometry looping?
>>> > > From: Zac Spitzer <zac.spitzer at gmail.com>
>>> > > Sent: Tuesday, July 07, 2009 10:49 PM
>>> > > To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
>>> Styles
>>> > >        using Style Order
>>> > > I am all in favour of the massaging approach. It puts the user in
>>> control.
>>> > > Whether the user pre-cooks their data in a db via sql or runs a script
>>> > which adds a column with a chosen layer key, it ends up being quite
>>> flexible.
>>> > > Being able to extract all features matched by a theme in a layer would
>>> > make such massaging rather straightforward.
>>> > > z
>>> > > On Wed, Jul 8, 2009 at 1:38 PM, Jason Birch<Jason.Birch at nanaimo.ca>
>>> wrote:
>>> > >> Maybe this kind of scenario is a good argument for a configurable data
>>> > caching layer (using sqlite of course!) in MapGuide.
>>> > >> ----- Original Message -----
>>> > >> <mapguide-internals-bounces at lists.osgeo.org>
>>> > >> Sent: Tue Jul 07 20:31:47 2009
>>> > Styles      using Style Order
>>> > >> Keep in mind that the filters used by a theme can be very broad:
>>> > >>  * they can be expressions involving multiple attributes
>>> > >>  * they can use any functions supported by FDO's expression engine
>>> > >>  * the rules may be against one attribute but with out-of-order ranges:
>>> > >>         rule 1: all cities with population < 1000
>>> > >>         rule 2: all cities with population >= 100000
>>> > >>         rule 3: all cities with population >= 1000 and < 100000
>>> > >> In each of these cases the provider ordering support cannot give you
>>> the
>>> > draw order behavior you want.  The ordering support only works for a
>>> subset
>>> > of themes; you would have to analyze the theme to see if it's "compatible"
>>> > with the provider ordering support, and if it isn't fall back to some
>>> other
>>> > algorithm to give you the draw order behavior you want.
>>> > >> I'm becoming more and more fond of the data massaging workaround:
>>> > >>  * it handles all possible filters
>>> > >>  * it only has to be done once as a preprocessing step (assuming your
>>> > >> data is static)
>>> > >>  * you will get top performance when rendering the data since only one
>>> > >> rendering pass is needed
>>> > >> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac
>>> > >> Spitzer
>>> > >> Sent: Tuesday, July 07, 2009 11:01 PM
>>> > >> On Wed, Jul 8, 2009 at 7:56 AM, Tom
>>> Fukushima<tom.fukushima at autodesk.com>
>>> > wrote:
>>> > >>> Hi Zac,
>>> > >>> Please also update the following statement in the RFC: "The only work
>>> > around currently is to break road networks into separate layers." to read
>>> > as...
>>> > >>> There are three possible known work arounds:
>>> > >>> 1) Break the road networks into separate layers.
>>> > >>> 2) Render the roads using composite type styles and specify the
>>> > RenderingPass appropriately (see RFC 29 for details).
>>> > >>> 3) Set up the data source so that it returns readers with the features
>>> > in the correct draw order.
>>> > >> ok, I added three workarounds in.
>>> > >>> For #3, Walt gave a description of this in one of his emails.  I have
>>> > extracted it for you here for your reference...
>>> > >>> Implement a utility which creates a data set optimized for a theme:
>>> > >>> * the utility will read the layer definition containing the themes
>>> > >>> * it will query the original data set once using each rule's filter,
>>> > >>> and write those features to a new data set (it needs to be a format
>>> > >>> which returns features in the order they were written)
>>> > >> this can be done pretty easily in php or c# via the mg api. going this
>>> > >> approach, massaging the data would also most likely end up elimating
>>> > >> any complex expression filters,
>>> > >>> * update your layer to use the new data set - the features will come
>>> > >>> in with the right order
>>> > >>> Also, we're not sure which, if any, data source #3 will work with. But
>>> > if it does work, it will be the most efficient one.  So perhaps, we should
>>> > leave out #3 above until someone tries it out and verifies that it works.
>>> > >> do you the potential datasource problem is that they don't perform
>>> > ordering?
>>> > >> SDF does via
>>> > >> http://fdo.osgeo.org/files/fdo/docs/SDF/_i_extended_select_8h-source.h
>>> > >> tml
>>> > >> http://trac.osgeo.org/fdo/wiki/FDORfc26
>>> > >> pretty much all database servers do natively?
>>> > >>> Thanks
>>> > >>> Tom
>>> > >>> Spitzer
>>> > >>> Sent: Friday, June 26, 2009 7:02 PM
>>> > >>> I have updated the RFC and added a FDO RFC for Ordering support
>>> > >>> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc69
>>> > >>> http://trac.osgeo.org/fdo/wiki/FDORfc40
>>> > >>> z
>>> > >>> On Sat, Jun 27, 2009 at 12:40 AM, Walt
>>> > >>> Welton-Lair<walt.welton-lair at autodesk.com> wrote:
>>> > >>>> They either split things up into multiple layers, as you say, or they
>>> > use the rendering pass behavior in the enhanced stylization (currently no
>>> UI
>>> > for the latter, so that complicates that one).  Both will have similar
>>> > performance impact as what's proposed in the RFC - both end up making the
>>> > same number of FDO queries.  And if you read ticket 618 referenced by the
>>> > RFC, the number of queries is a concern.
>>> > >>>> I would love to see MapGuide be able to support this behavior.  But
>>> > without a good / novel approach for doing this the performance impact will
>>> > be atrocious.  There are customers who have themed layers with 100's of
>>> > rules, and changing the default stylization behavior to have draw order
>>> > match rule order will not work for those maps performance-wise.  I think
>>> at
>>> > minimum the RFC will need to be updated to make this behavior optional
>>> > (default is off).  And that means a layer definition schema change.
>>> > >>>> Paul Spencer
>>> > >>>> Sent: Friday, June 26, 2009 9:18 AM
>>> > >>>> How would someone achieve the desired effect now?  From what I
>>> > >>>> understand (and I am not a power user of mapguide by any standard of
>>> > >>>> measurement), you would need to create several layer definitions
>>> > >>>> each with a filter and theme those layers for each road class?
>>> > >>>> how would performance for:
>>> > >>>> - for each rule, construct an FDO query filtered by the rule's
>>> > >>>> condition
>>> > >>>> - render all features using the rule's style
>>> > >>>> differ from having separate layers?
>>> > >>>> Yours confusedly ;)
>>> > >>>> Paul
>>> > >>>> On 25-Jun-09, at 11:06 PM, Walt Welton-Lair wrote:
>>> > >>>>> "Can some elaborate on how the server currently handles this?"
>>> > >>>>> Handles what?
>>> > >>>>> The current code iterates once over the features (ignore the
>>> > >>>>> compound line style example).  For every feature it evaluates the
>>> > >>>>> filters defined by the rules (in the order that the rules are
>>> > >>>>> specified).  Once it finds a matching rule it applies its style to
>>> > >>>>> the feature.
>>> > >>>>> With compound line styles we make a pass over all the features for
>>> > >>>>> each line style.  So for a compound line style containing M styles
>>> > >>>>> we make M FDO queries.
>>> > >>>>> With rendering passes (RFC 29) we also iterate over all the layer's
>>> > >>>>> features for each rendering pass.  The more passes you define the
>>> > >>>>> more queries you make.
>>> > >>>>> How to implement your RFC?
>>> > >>>>> option 1
>>> > >>>>> - Make a pass over the features for each rule.
>>> > >>>>> - During each pass only render the features that satisfy the rule
>>> > >>>>> for that pass.
>>> > >>>>> - If there are M rules you will make M FDO queries.
>>> > >>>>> => performance (speed) will be unacceptable for anything more than
>>> > >>>>> a few themes
>>> > >>>>> option 2
>>> > >>>>> - Make one query against all the features, remembering (in memory?)
>>> > >>>>> all the feature information (attributes / geometry) needed by
>>> > >>>>> stylization.
>>> > >>>>> - During the initial pass render the features for the first rule.
>>> > >>>>> - Iterate over the remaining rules in order, rendering the features
>>> > >>>>> for each rule.
>>> > >>>>> => performance (memory use) will be unacceptable for data sources
>>> > >>>>> containing large numbers of features => this approach goes against
>>> > >>>>> the MG architecture of not keeping feature data in memory during
>>> > >>>>> stylization (we already break that rule with labels which is what
>>> > >>>>> leads to high memory usage spikes for some maps)
>>> > >>>>> option 3
>>> > >>>>> - Allocate one image per rule.
>>> > >>>>> - Make one query against all the features, and render each feature
>>> > >>>>> into the image corresponding to the rule it satisifes.
>>> > >>>>> - Merge all images at the end.
>>> > >>>>> => performance (speed + memory) will be unacceptable for anything
>>> > >>>>> more than a few themes
>>> > >>>>> option 4
>>> > >>>>> ________________________________________
>>> > >>>>> [mapguide-internals-bounces at lists.osgeo.org
>>> > >>>>> ] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
>>> > >>>>> Sent: Thursday, June 25, 2009 10:36 PM
>>> > >>>>> At the moment the only way to achieve this is to split the road
>>> > >>>>> network out into multiple layers which is rather ugly.
>>> > >>>>> Taking a road network as the example here, it's only at the
>>> > >>>>> intersections where this problem occurs.
>>> > >>>>> z
>>> > >>>>> On Fri, Jun 26, 2009 at 12:28 PM, Walt
>>> > >>>>>> "Proposed solution: Add support to the rendering engine to render
>>> > >>>>>> layer styles in ordered passes."
>>> > >>>>>> I'd like to see some concrete suggestions in the RFC on how to
>>> > >>>>>> actually do this efficiently.  Just consider a conservative use
>>> > >>>>>> case - say around 10  rules.
>>> > >>>>>> Walt
>>> > >>>>>> Sent: Thursday, June 25, 2009 9:29 PM
>>> > >>>>>> Subject: [mapguide-internals] MapGuide RFC 69 - Rendering Layer
>>> > >>>>>> I have posted a new RFC
>>> > >>>>>> Zac Spitzer -
>>> > >>>>>> http://zacster.blogspot.com
>>> > >>>>>> +61 405 847 168
>>> > >>>>>> _______________________________________________
>>> > >>>>>> mapguide-internals mailing list
>>> > >>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>>> > >>>>> Zac Spitzer -
>>> > >>>>> +61 405 847 168
>>> > >>>>    Paul Spencer
>>> > >>>>    Chief Technology Officer
>>> > >>>>    DM Solutions Group Inc
>>> > >>>>    http://research.dmsolutions.ca/
>>> > >>> Zac Spitzer -
>>> > >>> +61 405 847 168
>>> > >> Zac Spitzer -
>>> > >> +61 405 847 168
>>> > > Zac Spitzer -
>>> > > +61 405 847 168
>>> > Zac Spitzer -
>>> > +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
+61 405 847 168
More information about the mapguide-internals
