[mapguide-internals] Installer on Branch?
Trevor Wekel trevor_wekel at otxsystems.com
Wed Jun 23 23:28:14 EDT 2010
Hi Jason, Hi Jackie,
The work is still ongoing for the 64 bit installer.  I have been able to get relatively far with just adding x64 configurations to the existing projects and solutions.  This might change when I get to Apache/PHP/Tomcat.  I am keeping my fingers crossed.  Having one set of projects and solutions should make maintenance and reuse a bit easier.
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: June 23, 2010 7:58 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Installer on Branch?
Trevor, I noticed that you added configurations to the installer for
x64. My understanding is that the amount of reuse potential between
x64 and x86 installers is extremely low; it may make more sense to
just have a separate x64 solution.
On 2010-06-23, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> Hi Crispin,
> I branched MapGuide 2.2 "MgDev" to open up trunk for new development work.
> I did not branch "Installer" since the 2.2 installer is still a work in
> progress.  The build64.bat scripts are partially working for IIS/.Net.
> IIS/PHP, Apache/PHP, and Apache/Tomcat/Java still need to be looked at.
> Once the installer is fully working, I will branch it for MapGuide 2.2.
> Regards,
> Trevor
> Crispin_at_1Spatial
> Sent: June 23, 2010 10:33 AM
> To: mapguide-internals at lists.osgeo.org
> Subject: [mapguide-internals] Installer on Branch?
> Hi,
> I am going through the process of creating a Win64 build from \Branch2.2
> (some manual steps/hacks but seems reasonable - though maybe issues with
> webapi - lots of noise from build64.bat).  But more another time.
> This query is if the \Installer should branch at the same time as \MgDev as
> there seem to be things that need to be kept in sync to re-create a
> versioned redistributable?
> http://osgeo-org.1803224.n2.nabble.com/Installer-on-Branch-tp5214092p5214092.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
