[mapguide-internals] Re: Getting closer with 64 bit installer
Trevor Wekel trevor_wekel at otxsystems.com
Mon Jun 28 12:46:54 EDT 2010
Hi Crispin,
With Jason's help I made a bunch of WiX changes late last night.  See http://trac.osgeo.org/mapguide/changeset/4986.  The installer should be more 64 bit compliant now.  However, I am getting nasty behaviour with both the PHP and .Net web extensions now http://trac.osgeo.org/mapguide/ticket/1388.
I will send a follow up post once I've figured out what is going on.  I will try the create session from the web tier test pages.  Does Enumerate Resources work for you?
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Crispin_at_1Spatial
Sent: June 28, 2010 10:24 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Re: Getting closer with 64 bit installer
Trevor,
I ran your installer for native IIS / .net on 64-bit Win7 but when I tried
to do a getsession from the webtier tests I got an IIS message saying,
basically, no (see below).
I'll continue to try and build my own, but any suggestions welcome.
 Crispin
Error Summary
HTTP Error 500.21 - Internal Server Error
Handler "MapGuide MapAgent ISAPI handler" has a bad module "IsapiModule" in
its module list
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Getting-closer-with-64-bit-installer-tp5228366p5231556.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
