[mapguide-internals] Re: Getting closer with 64 bit installer
Trevor Wekel trevor_wekel at otxsystems.com
Mon Jun 28 14:20:07 EDT 2010
Ok.  Here's an update.  After more debugging I narrowed down what was causing the crash.  IIS wasn't picking up the Mentor dictionary path immediately after the installation.  A !!REEEEBOOOT!! of the machine solved the issue.  I have posted a new build to
http://download.osgeo.org/mapguide/testing/MapGuideOpenSource-2.2.0.4982-Beta1-x64.exe
So far, I have been able to validate the following:
Windows 2008 R2 IIS/.Net
- MapAgent test pages work
- Site Administrator works
- Maestro can connect
- Sheboygan Basic map loads, pans, zooms, selects, buffers
Windows 2008 R2 IIS/PHP
  Issue: Buffer fails to display
- Sheboygan Fusion map loads, pans, zooms, selects, buffers
I will try to do some Apache testing later today.
Regards,
Trevor
-----Original Message-----
Sent: June 28, 2010 10:47 AM
To: 'MapGuide Internals Mail List'
Subject: RE: [mapguide-internals] Re: Getting closer with 64 bit installer
Hi Crispin,
With Jason's help I made a bunch of WiX changes late last night.  See http://trac.osgeo.org/mapguide/changeset/4986.  The installer should be more 64 bit compliant now.  However, I am getting nasty behaviour with both the PHP and .Net web extensions now http://trac.osgeo.org/mapguide/ticket/1388.
I will send a follow up post once I've figured out what is going on.  I will try the create session from the web tier test pages.  Does Enumerate Resources work for you?
Regards,
Trevor
More information about the mapguide-internals mailing list
