[mapguide-internals] Re: Getting closer with 64 bit installer
Jackie Ng
jumpinjackie at gmail.com
Mon Jun 28 17:47:03 EDT 2010
Hi Trevor,
I recently pulled the reboot requirement from the installer for versions of
Windows newer than XP, because testing has found the mgserver.exe picks up
the freshly set MENTOR_DICTIONARY_PATH environment variable without needing
to reboot.
Is this not the case in a 64-bit environment?
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Getting-closer-with-64-bit-installer-tp5228366p5232827.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
