[mapguide-internals] Re: Getting closer with 64 bit installer
Trevor Wekel
trevor_wekel at otxsystems.com
Mon Jun 28 18:02:33 EDT 2010
Hi Jackie,
The Server picks it up. The Web Extensions do not.
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: June 28, 2010 3:47 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Re: Getting closer with 64 bit installer
Hi Trevor,
I recently pulled the reboot requirement from the installer for versions of
Windows newer than XP, because testing has found the mgserver.exe picks up
the freshly set MENTOR_DICTIONARY_PATH environment variable without needing
to reboot.
Is this not the case in a 64-bit environment?
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Getting-closer-with-64-bit-installer-tp5228366p5232827.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
