[mapguide-internals] Moving more config options into MapDefintion
Resource Headers (RFC?)
Jason Birch
jason at jasonbirch.com
Fri Mar 26 22:24:12 EDT 2010
I think I like the idea of storing properties separate from the
definition but not fully clear on it yet.
I'd also love to see base map (tile set definition?) as a separate
resource that could be easily referenced from multiple mapdefinitions,
safe from accidental deletion, etc...
This could take advantage of resource header to define tile dimensions
and format?
On 2010-03-26, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> splitting this bit into a separate thread from the RFC90 post...
> Given the static nature and global nature of anything done via
> serverconfig.ini,
> this is all or nothing. I think we have resource headers which could be
> used a lot more than we do currently, that way we can make map specific
> configuration overrides.
> For example, image format, selection color and meta tile factor would
> all be good candidates for setting via resource headers. That would
> avoid having to rev the xml def's to add such functionality.
> Being able to tune maps configurationwithout changing a global setting
> and restarting the server would be a good thing...
> thoughts?
> z
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
