[mapguide-internals] /branches root directory reserved only for MapGuide?
Jason Birch jason at jasonbirch.com
Mon May 3 12:30:45 EDT 2010
I'm not sure why it is important that the branch structure matches the
trunk. MapGuide (and its related installer) is a distinct product from
Maestro, so the MapGuide version numbers don't make sense. We've
already adopted this product-based system under tags.
Ideally we'd have a separate svn tree (and Trac) for Maesto, but
didn't persue this at the time. Should this be revisited?
On 2010-05-03, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> Hmm... Branches should match the structure under trunk.  I am personally ok
> with having Tools out of sync with MgDev and Installer.  We should probably
> add a compatibility section to the wiki somewhere.
> /branches/2.1/Tools (whatever version 2.1 means for each of the tools, not
> in sync with MgDev and Installer)
> /branches/2.1/MgDev (version 2.1 for MapGuide Server and Web Extensions)
> /branches/2.1/Installer (installer for version 2.1 of MapGuide)
> Trevor
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
> Birch
> Sent: May 3, 2010 9:17 AM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] /branches root directory reserved only for
> MapGuide?
> Maestro versions don't normally match MapGuide versions, and are on a
> different release cycle. I personally feel that it would make more
> sense to have distinct Maestro branches than to place them within
> existing MapGuide branches.
>> I'm ok with using the existing branching mechanism. The branches should
>> match the trunk layout.
>> /branches/2.1/Tools/Maestro
>> (Just add Tools/Maestro)
>> /branches/2.2/Installer
>> /branches/2.2/MgDev
>> (At some point we should set this branch up.  Was hoping to get RFC 90 in
>> first)
>> Regards,
>> Trevor
>> Birch
>> Sent: May 3, 2010 3:00 AM
>> for
>> MapGuide?
>> I think we discussed this when we were initially bringing Maestro in.
>> It was a while back, but I think the intention was to just use a
>> prefix for the Maestro branches (/branches/Maestro-2.1, etc...)
>> similar to how its done in tags.
>> On 2010-05-03, Jackie Ng <jumpinjackie at gmail.com> wrote:
>>> Hi All,
>>> I'd like to make a "2.1" branch for Maestro since I plan to do some
>>> massive
>>> API changes/enhancements/overhauls post-2.1
>>> Can I put a 2.1 branch under the top-level "branches" svn directory? Or
>>> is
>>> this only for MapGuide's use?
>>> - Jackie
>>> View this message in context:
>>> http://osgeo-org.1803224.n2.nabble.com/branches-root-directory-reserved-only-for-MapGuide-tp4996834p4996834.html
>>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
