[mapguide-internals] /branches root directory reserved only for
MapGuide?
Tom Fukushima
tom.fukushima at autodesk.com
Mon May 3 16:11:01 EDT 2010
For the following argument: I'm assuming that Maestro doesn't have the capability to detect when it is working with an older server and dumb down the XML and UI for it appropriately. If it does have that capability then please ignore.
Personally, I dislike the fact that Maestro is on its own release cycle with its own version numbers because it makes it tougher to tell which version to use with a particular version of MapGuide. MapGuide does update schemas, and the authoring tool should always use the latest one where possible. If Maestro uses the same version numbers we can see which version of MGOS it is in sync with. Because of this I think that Maestro should use the same branches that is used by the server, web tier and installer. And because of this I think our current directory structure is fine.
BTW, having Maestro, MgDev and Installer in the same branch does not mean that they have to be released at the same time.
Cheers
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Monday, May 03, 2010 10:59 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] /branches root directory reserved only for MapGuide?
Other open source projects do follow similar trunk/branch conventions.
http://svn.apache.org/repos/asf/httpd/httpd/trunk/
http://svn.apache.org/repos/asf/httpd/httpd/branches/2.0.x/
http://svn.apache.org/repos/asf/httpd/httpd/branches/2.2.x/
I like the fact that the "Tools" resides under the MapGuide vault. The tools do not work against any other GIS product so maintaining the association is reasonable in my mind.
Another alternative is to move Tools to the root of the tree and trunk/branch each tool separately. We sort of do this for the sandboxes right now. We should also remove Tools from mapguide/trunk/Tools once we make this change.
http://svn.osgeo.org/mapguide/Tools/Maestro/trunk
http://svn.osgeo.org/mapguide/Tools/Maestro/branches/2.1
http://svn.osgeo.org/mapguide/Tools/GISTool/trunk
http://svn.osgeo.org/mapguide/Tools/GISTool/branches/1.0
The code bases under Maestro/trunk and Maestro/branches/2.1 should have an identical layout.
Regards,
Trevor
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: May 3, 2010 10:31 AM
Subject: Re: [mapguide-internals] /branches root directory reserved only for MapGuide?
I'm not sure why it is important that the branch structure matches the
trunk. MapGuide (and its related installer) is a distinct product from
Maestro, so the MapGuide version numbers don't make sense. We've
already adopted this product-based system under tags.
Ideally we'd have a separate svn tree (and Trac) for Maesto, but
didn't persue this at the time. Should this be revisited?
On 2010-05-03, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> Hmm... Branches should match the structure under trunk. I am personally ok
> with having Tools out of sync with MgDev and Installer. We should probably
> add a compatibility section to the wiki somewhere.
> /branches/2.1/Tools (whatever version 2.1 means for each of the tools, not
> in sync with MgDev and Installer)
> /branches/2.1/MgDev (version 2.1 for MapGuide Server and Web Extensions)
> /branches/2.1/Installer (installer for version 2.1 of MapGuide)
> Trevor
> Birch
> Sent: May 3, 2010 9:17 AM
> MapGuide?
> Maestro versions don't normally match MapGuide versions, and are on a
> different release cycle. I personally feel that it would make more
> sense to have distinct Maestro branches than to place them within
> existing MapGuide branches.
>> I'm ok with using the existing branching mechanism. The branches should
>> match the trunk layout.
>> /branches/2.1/Tools/Maestro
>> (Just add Tools/Maestro)
>> /branches/2.2/Installer
>> /branches/2.2/MgDev
>> (At some point we should set this branch up. Was hoping to get RFC 90 in
>> first)
>> Regards,
>> Trevor
>> Birch
>> Sent: May 3, 2010 3:00 AM
>> for
>> MapGuide?
>> I think we discussed this when we were initially bringing Maestro in.
>> It was a while back, but I think the intention was to just use a
>> prefix for the Maestro branches (/branches/Maestro-2.1, etc...)
>> similar to how its done in tags.
>> On 2010-05-03, Jackie Ng <jumpinjackie at gmail.com> wrote:
>>> Hi All,
>>> I'd like to make a "2.1" branch for Maestro since I plan to do some
>>> massive
>>> API changes/enhancements/overhauls post-2.1
>>> Can I put a 2.1 branch under the top-level "branches" svn directory? Or
>>> is
>>> this only for MapGuide's use?
>>> - Jackie
>>> View this message in context:
>>> http://osgeo-org.1803224.n2.nabble.com/branches-root-directory-reserved-only-for-MapGuide-tp4996834p4996834.html
>>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
