[mapguide-internals] /branches root directory reserved only for MapGuide?
Jason Birch jason at jasonbirch.com
Mon May 3 17:16:09 EDT 2010
Ignoring :)
(Maestro is generally backwards-compatible)
Maestro is on a totally different release cycle than MapGuide. I
wouldn't want to see the next+1 version of Maestro not be able to do a
full-version jump (as feature additions justify) just to keep its
version numbering in sync with MapGuide.
We should do a better job of communicating Maestro's version
compatibility though, in the wiki and on the splash screen...
On 2010-05-03, Tom Fukushima <tom.fukushima at autodesk.com> wrote:
> Hi,
> For the following argument: I'm assuming that Maestro doesn't have the
> capability to detect when it is working with an older server and dumb down
> the XML and UI for it appropriately.  If it does have that capability then
> please ignore.
> Personally, I dislike the fact that Maestro is on its own release cycle with
> its own version numbers because it makes it tougher to tell which version to
> use with a particular version of MapGuide.  MapGuide does update schemas,
> and the authoring tool should always use the latest one where possible.  If
> Maestro uses the same version numbers we can see which version of MGOS it is
> in sync with. Because of this I think that Maestro should use the same
> branches that is used by the server, web tier and installer.  And because of
> this I think our current directory structure is fine.
> BTW, having Maestro, MgDev and Installer in the same branch does not mean
> that they have to be released at the same time.
> Cheers
> Tom
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor
> Wekel
> Sent: Monday, May 03, 2010 10:59 AM
> To: MapGuide Internals Mail List
> Subject: RE: [mapguide-internals] /branches root directory reserved only for
> MapGuide?
> Other open source projects do follow similar trunk/branch conventions.
> http://svn.apache.org/repos/asf/httpd/httpd/trunk/
> http://svn.apache.org/repos/asf/httpd/httpd/branches/2.0.x/
> http://svn.apache.org/repos/asf/httpd/httpd/branches/2.2.x/
> I like the fact that the "Tools" resides under the MapGuide vault.  The
> tools do not work against any other GIS product so maintaining the
> association is reasonable in my mind.
> Another alternative is to move Tools to the root of the tree and
> trunk/branch each tool separately.  We sort of do this for the sandboxes
> right now.  We should also remove Tools from mapguide/trunk/Tools once we
> make this change.
> http://svn.osgeo.org/mapguide/Tools/Maestro/trunk
> http://svn.osgeo.org/mapguide/Tools/Maestro/branches/2.1
> http://svn.osgeo.org/mapguide/Tools/GISTool/trunk
> http://svn.osgeo.org/mapguide/Tools/GISTool/branches/1.0
> The code bases under Maestro/trunk and Maestro/branches/2.1 should have an
> identical layout.
> Regards,
> Trevor
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: May 3, 2010 10:31 AM
> Subject: Re: [mapguide-internals] /branches root directory reserved only for
> MapGuide?
> I'm not sure why it is important that the branch structure matches the
> trunk. MapGuide (and its related installer) is a distinct product from
> Maestro, so the MapGuide version numbers don't make sense. We've
> already adopted this product-based system under tags.
> Ideally we'd have a separate svn tree (and Trac) for Maesto, but
> didn't persue this at the time. Should this be revisited?
> On 2010-05-03, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
>> Hmm... Branches should match the structure under trunk.  I am personally
>> ok
>> with having Tools out of sync with MgDev and Installer.  We should
>> probably
>> add a compatibility section to the wiki somewhere.
>> /branches/2.1/Tools (whatever version 2.1 means for each of the tools, not
>> in sync with MgDev and Installer)
>> /branches/2.1/MgDev (version 2.1 for MapGuide Server and Web Extensions)
>> /branches/2.1/Installer (installer for version 2.1 of MapGuide)
>> Trevor
>> Birch
>> Sent: May 3, 2010 9:17 AM
>> for
>> MapGuide?
>> Maestro versions don't normally match MapGuide versions, and are on a
>> different release cycle. I personally feel that it would make more
>> sense to have distinct Maestro branches than to place them within
>> existing MapGuide branches.
>>> I'm ok with using the existing branching mechanism. The branches should
>>> match the trunk layout.
>>> /branches/2.1/Tools/Maestro
>>> (Just add Tools/Maestro)
>>> /branches/2.2/Installer
>>> /branches/2.2/MgDev
>>> (At some point we should set this branch up.  Was hoping to get RFC 90 in
>>> first)
>>> Regards,
>>> Trevor
>>> Birch
>>> Sent: May 3, 2010 3:00 AM
>>> for
>>> MapGuide?
>>> I think we discussed this when we were initially bringing Maestro in.
>>> It was a while back, but I think the intention was to just use a
>>> prefix for the Maestro branches (/branches/Maestro-2.1, etc...)
>>> similar to how its done in tags.
>>> On 2010-05-03, Jackie Ng <jumpinjackie at gmail.com> wrote:
>>>> Hi All,
>>>> I'd like to make a "2.1" branch for Maestro since I plan to do some
>>>> massive
>>>> API changes/enhancements/overhauls post-2.1
>>>> Can I put a 2.1 branch under the top-level "branches" svn directory? Or
>>>> is
>>>> this only for MapGuide's use?
>>>> - Jackie
>>>> View this message in context:
>>>> http://osgeo-org.1803224.n2.nabble.com/branches-root-directory-reserved-only-for-MapGuide-tp4996834p4996834.html
>>>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-internals mailing list
>>>> mapguide-internals at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
