[mapguide-internals] RE: GCC 4.4 and Oem upgrade
Trevor Wekel trevor_wekel at otxsystems.com
Mon May 10 13:20:18 EDT 2010
I know the .Deb tools will code >= for the package versions.  I assume the .rpm tools will do the same.
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: May 10, 2010 10:25 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] RE: GCC 4.4 and Oem upgrade
Me too, with the addition that we should maintain a page on the wiki
indicating latest tested/supported versions.  There will likely be cases
where newer versions of libraries are released that aren't compatible with
MapGuide, and it would be a good idea to have an easy way for folks to
verify they are using supported versions when they run into problems.
I'm assuming that the package tools allow you to specify a minimum required
version as well?
Jason
On 10 May 2010 08:53, Tom Fukushima wrote:
> Thanks. I think that we should go with #2.
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
